[1.2 TDI ANY] Sammelthread für Kupplungsnehmerzylinder mit Hall-Sensor-Umbau + HINWEIS!
Eumeltier antwortete auf Phoenix A2's Thema in Technik
I would check following situations: Motor off, N Motor off, D Motor off, D, brake pedal pressed Motor on, N Motor on, D Motor on, D, brake pedal pressed What happens in each situation with the G162 value and the both clutch position values? -
Germantas antwortete auf Phoenix A2's Thema in Technik
VCDS show 99.6% and voltage is if i remember correctly 3.85v. I did video when engine is running, and gear shifter is in D. When I am starting a car in S position, then go to N and D, engine just revving buy car not driving (my video did in this stage). But, when starting engine in N and then to D, not always but often, clutch is disengaging, and I can drive. I didn't check how is when engine not runs. Will do it today. What more i can try or read with VCDS to be shure there is a problem? -
Hello everyone, I am new at the club, I live in Denmark and I am finally about to became owner of an Audi A2 1.2 TDI 3L tiptr. I haven’t bought it yet, so if anyone knows about a very well kept A2 in grey colour with low KM, please let me know The one I am purchasing is missing some of the things I would like to implement, so I’d love to hear if anyone here could help. Interiors: • Front controls, navigation plus or one of the other factory ones, and the underneath controls. • maybe some plastic switches • Armrest (if possible ) Exterior: • Rear A2 badge and rear Audi logo badge • tyres rims ( not sure about which ones) • Fog lights ( if possible ) tech: • Cruise control installation I am looking forward to hearing from you Many thanks in advance Best Cesare
Das ist so ziemlich immer der Frischluftgebläseregler, wie @AudiA216RS schon angemerkt hat. Kostet nicht die Welt, aber leider ist der Tausch eine fummelige Angelegenheit. Hier ist er beschrieben: https://a2-freun.de/forum/forums/topic/17632-frischluftgebläse-frischluftgebläseregler-aus-einbauen/ Das ist leider Humbug, der Regler geht beim A2 im Alter schon mal "kaputt". Moderator: Die themenfremde Frage von @pittera2 habe ich ausgeblendet, da sie nichts mit der Klima zu tun hat. Bitte deine Frage in einem passenden Thema stellen oder bei Bedarf ein eigenes Thema erstellen. - Nagah
Damit würdest du Unmengen von Leuten einen Gefallen tun, denn die Blenden haben massive Softlackschäden, die alten Schalter ohne Softlack werden immer teurer gehandelt, wenn man überhaupt einen findet. Eine Blende, in die die Golf IV Schalter passen wäre glaube ich sehr gefragt. Müsste man gegbenenfalls selber in Soul schwarz lackieren können. Das Problem ist die Lichtdurchlässigkeit für die Symbole der Leuchweitenverstellung/Armaturenbrettbeleuchtung. Die Blende könntest du ja so drucken, dass der Golf Schalter samt Ring passt, da wäre es dann mit den Symbolen des Rings kein Problem mit der Hinterleuchtung.
Vielen Dank dafür, wieder was sehr hilfreiches gelernt ....
Es ist sehr warscheinlich der Frischluftgebläseregler fällig. Hatte ich auch schon.
Ich hatte das Problem bei einem E46 nach Tausch der Benzinpumpe. Es hat sich herausgestellt das die neue kein Rückschlagventil hat. Als ich dies dann in der Leitung nachgerüstet habe, hatte sich das Problem erledigt.
Danke Nagah - nochmal auf die Frage mit dem Upload zurückzukommen? 😎
Moderator: Kurze Info vom Moderator: Der Technik-Bereich wird von mir extrem streng moderiert. Es hat sich gezeigt, dass viele Technik-Themen in Foren nach Jahren einfach durch allerlei Gespräche stark verwässern und dann die Suche für betroffene Nachfolger stark erschwert. Daher lösche ich (ausschließlich!) im Technik-Bereich rigoros alles was nicht eng zum Thema des Beitrags gehört. Bitte nicht wundern. Auch hier habe ich schon alles "off topic" ausgeblendet. Viel Erfolg bei der Problemsuche. - Nagah
Der Aussagekraft vom mit Schätzeisen gemessenen Spannungsabfällen im Milivoltbereich an Sicherungen würde ich jetzt mal als theoretischen Ansatz bezeichnen. Jeder Übergangswiderstand an Messleitungen oder Buchsen hat einen erheblichen Einfluss. Wieviel Spannung liegt an der Batterie an bei laufendem Motor? Deutlich über 14V? Wie schnell bricht diese Spannung zusammen nach Motorstop? Wie groß ist der Stromfluss an der Batteriezuleitung nach einschlafen der Stg.? Welche "Herausforderungen"? Wie alt ist die Batterie? .
Moderator: Thema in die Verbraucherberatung verschoben. - Nagah
Leider ist das Video recht einfacher KI-Müll. Damit wird Youtube nun immer weiter geflutet da es recht einfach ist mit solchen Videos klicks zu generieren. Über den Wahrheitsgehalt macht sich aber kaum einer mehr gedanken.
Leider schaffe ich es auch nur am Samstag und hoffe, dass ich trotzdem ein paar bekannte Gesichter sehen werde. Vielen Dank schon mal an das Orga-Team! LG Uli
Es versucht es
Your video don't show the value of the clutch cylinder (G162). As the clutch position is shown at ~100%, the voltage value for G162 should be constant near 4V. Is this correct? But you write: Because if the clutch cylinder would be active engaging and disengaging all the time, the constantly running pump would be understandable. But the 100% value would say that the clutch is and stays open the whole time. Your video, is it in D or N? Does anything change if the motor is not running? -
[1.4 AUA] Kaltstartprobleme bei leererem Tank (behoben)
A2 HL jense antwortete auf Ringfuchs's Thema in Technik
ot: Bei deinem Mod ja zum Glück nicht mehr, das muss ich noch nachbauen, das Relais liegt schon bereit ... :-) -
Ah, ok! Da hätte man noch einfacher ran gehen können. Ich musste aber eh Kabel zur Tür legen
Teilnehmerliste 19.9. und 20.9.25 - 25 Jahre Audi A2 in Neckarsulm
seinelektriker antwortete auf morgoth's Thema in Treffen
Aktuelle Teilnehmerlsite verwendet. Anpassung von @bart01 zugefügt. morgoth, eine Person, ein A2, kobaltblau Fr | Abendessen Freitag Nupi & Tatzino, 2 Personen, ein A2 Senior, äh Lichtsilber met. Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht) A2magica, 1 Person, A2 "CS: Mattschwarz an Estorilblau Kristalleffekt", Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht) seinelektriker, 1 Person, A2 "CS: Misanorot Perleffekt", Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht) Granitei 2 Personen, ein A2, akoyasilber Fr.-Sa. + Ausfahrt, Hotel Küffner Hof gebucht. durnesss 2 Personen, ein A2, silber/matt/grau, Fr-Sa Hotel Küffler Hof, müssen spätestens Sa. Mittag zurück. Zweierlehrling, eine Person, ein A2, schwarz a2-701, eine Person, ein A2, CS:blau Seb Gurkyh, eine Person, ein A2 Milke, 1 Person , ein A2, Amulletrot, Fr 1 Person, Sa + Ausfahrt + Essen mit 4 Personen (Erw. + 2 Kinder) AudiA216RS nebst Streetfreak, zwei Personen, A2 CS Sprintblau, A2 CS Papayaorange, Do-Sa Hotel Küffler Hof Krebserl, 1 Person in einem meiner gelben A2-CS Elch A2 1-2 Personen ein A2 Kastellrot A2-s-line, 1 Person + evtl 2 Kids, einA2, ebonyschwarz - wenn, dann nur am Samstag Freitag ChristianFfm, eine Person, ein A2,optional Orga der PR Frickler, eine Person und ggf. 2 Zwerge, ein A2 A2-Aluflitzer, eine Person, ein A2, vermutlich schwarz (unter Vorbehalt vembicon, eine Person, ein Nicht-A2 olsta, 1-2 Personen, ein A2, Lichtsilber (vorr. nur Freitag) A2 HL Jense 1-2 Personen, mindestens 1, vielleicht 2 A2, auf jeden Fall Azurblau perleffekt, vielleicht zusätzlich CS blau Aida|Reisegruppe besteht aus: 1 Kind (Kita), 1 Kegel (erwachsen), 1 A2 (4G/LY3C) Istvan 1-3 Personen, ein A2 ebonyschwarz Sa + Ausfahrt 3ltdi|Reisegruppe besteht aus: 1 Kind (Kita) + Doppelkegel, vermutlich A2 3L grüne Pinie flipper493 1-2 Personen, ein A2 (nur Freitag) mamawutz + Frau mamawutz I 2 Personen, ein A2, Fr + Sa + Ausfahrt, (Hotel Küffner Hof gebucht, Delphingrau Audifanatiker 3 Personen, ein A2 (Atlantikblau) + ein weiterer A2 (Kastellrot) / Fr. + Sa. / FR. Abendessen + Zimmer Küffner-Hof HolgerBY, 1 Person, ein A2, ebonyschwarz HEY_A2, 1 Person, ein A2 Powdertiger, 1 A2 mauritiusblau, 1P jungera2ler, 2 Personen, 1x Colour.Storm Rot, 1x 3L Ebonyschwarz mit weißer Nase Joachim_A2, 1 - 2 Personen; 1x A2; Akoyasilber; Fr. + Sa. | Abendessen: Freitag, Küffner-Hof | Samstag: Teilnahme an Ausfahrt bis ca. 14:45 Uhr (nach Mittagessen auf Burg Stettenfels). murmeli 2 Personen , ein A2, Merlotrot Samstag + Ausfahrt AQuadrat 1-2 Personen, Papaya Orange FZR-rider 3-4 Personen, 2 A2, Atlantikblau & Kobaltblau YetAnotherA2Freund 1 Person, 1 A2, Ebonyschwarz-Perleffekt A2-Nerd 1-2 Personen, 1 A2, Kobaltblau audi22, 2 Pers, 1-2 A2`s, ebonyschwarz (& evtl. kobaltblau) bret, 1 pers, (1 A2) , Kristallblau. Noch ist nichts gebucht... bjoern1981 1 Pers, 1 A2, Ebonyschwarz Perleffekt ModiA2tdi, eine Pers, ein A2, silber (unter Vorbehalt) Kuestenbazi, 1-2 Personen, A2 FSI Color Storm Imolagelb Thomas L, 2 Personen; A2 1,4 islandgrün metaillic Praslin + 1 Person Audi A2 1,4 ATL silber MAK10 und Fauchilein 2 Personen Audi A2 1.4 ATL Color Storm Blau bart011-2 Personen, A2 1.4 Color Storm Imolagelb Fr + Sa + Ausfahrt, + Fr Abendessen Küffner Hof Mike Brachtvogel, 1 bis 2 Personen, Audi A2 1,6 FSI Ebony Schwarz Metallic A2-Sammler, 1-? Personen, A2 "in Planung" jfps, 1-? Personen, A2 "in Planung" A2-BW, 1 Person, 1 A2 1.4 Lichtsilber Metallic (voraussichtlich nur Freitag) Alu- Green 2 Personen, 1 A2 Lichtsilber DZ + AE 2 Personen pilot_malte 4 Personen, 1 A2 1.6 FSI piniengrün ulle0102 3 Personen ANY oder ATL, vielleicht auch beide Popeye82 2 Personen ANY Islandgrün, voraussichtlich nur Freitag SteSo, 1-2 Personen + evtl. 2Kids, A2 1.4 Schwarz metallic (nur am Samstag) basti11, 2 Personen + 1 Kid, A2 1.4TDI, silber (nur Freitag) Uli64 1 Person, A2 1.6 FSI Lichtsilber Metallic gonemillion 1 Person silber schwarz Martin Kathi A2 Personen, A2 1.4 AUA schwarz Fr. + Sa. |2 Personen | Abendessen: Freitag, Küffner-Hof Übernachtung gebucht | Samstag: Teilnahme an Ausfahrt Colortom Z1/P1/A1 A2 dti AMF Imolagelb,A- Tirol Tachostand fast 400t km Do bis Sa Kaiserin 1-2 Personen, nur Samstag ColorstormRHD 2 Personen,1.4 BBY Colorstorm Imolagelb, nur Freitag LeMans5 2 Personen, 1 Audi A2 S-line, Anthrazit, aus Tirol, von Do bis Sa Karlsruhe ? Personen, 1 A2, nur Freitag Silberteufel 2 Personen mit A2 - 1,4 ATL Akoyasilber Teilnahme mit Diner kein ÜF , Freitag + Samstag Morgen Phoenix A2 1 Person, 1 A2, Freitag + Samstag Morgen PROVOTEC 2 Personen, A2 Lichtsilber (unter Vorbehalt) A2^2 1 Person, A2 1.4 TDI Azurblau Freitag + Samstag Tomtath 1 Person Samstag nur 10 - 13 Uhr blauer CS 1,4 mit blauem Dach (unter Vorbehalt) ANY-Fahrerin 1 Person 1 A2 (ATL, schwarz, OSS) nur Samstag Leon1999 3 Personen, 1 A2 (AUA, Ebonyschwarz Perleffekt, OSS) voraussichtlich nur Freitag Leypi 1 Person Samstag BHC CS blau -
Habe mir grad den Beitrag über den A2 angesehen. Von dem was erzählt wurde, stimmt nicht alles - aber egal, mein A2 kommt mir überhaupt nicht vor wie ein 25 Jahre altes Auto .... natürlich ist er kein Neuwagen ... aber ich habe mit ihm einen zwei Jahre alten Jeep Avenger Elektro ersetzt ... das hat nix, aber auch überhaupt nix mit Mainstream zu tun .... sondern einfach mit einer Rückkehr zum einfachen Fahren wie früher, als man beim Autofahren noch alles selbst machen durfte/musste/konnte
Heute erst?? Krass!! Ist seit Mittwoch letzter Woche unterwegs .... -
Hydraulic fluid I changed to new and level is correct. When I open a door ,pump is running for maybe 30 sec, then stops until I start engine. Then will run again 30sec. Will stay until press a brake or trying to change a gear. When test run a car, I hear that pump is run constantly, because clutch is engaging and disengaging and gears is changing. Sounds like accumulator tank is bad, but it is totally new and even tried with use one who works perfectly on another car. -
Wie kommst du darauf?
