Aus ALT mach NEU - Kpl. Aufbereitung -
[1.2 TDI ANY] hydraulic oil pump constantly running
So I assume this is a very bad situation.... -
36
I'm quite sure, your clutch is working fine. You can check the clutch actuator's value in the measurements block #002. The clutch is open at a value >3V I think you have a problem getting the pressure up to a value where your system operates normally. There is also a measuring block for the pressure-sensor-voltage (I don't know the correct block at the moment). That matches to all what I see on the video. The car accepts gas (engine turns up) so it waits for having enough pressure to put a gear in and release the clutch. But it never reaches the point where pressure is high enough, so the car doesn't move. I think you have already tested what happens we you open the door and waits until pump stops. It should stop shorter than 1 minute. If it takes longer, the CU stops the pump to avoid damages (due to overload or dry run). If this works fine, there could be a problem with the N255 valve or your pressure gets lost in the gear actuator. A 2nd test could be, to switch on ignition and awaits the pump to stop. If it never stops, there remain several issues. Maybe you can try to put a dedicated gear in and check the pump's behavior. For example if it stops with Reverse gear but goes on in LG3-4 it might be a hint, that the gear actuator cause the trouble. On the other hand, if it doesn't matter what the gear actuator does but it never stops when clutch is open, the N255 could be the problem. Have you checked what kind of oil was used in the hydraulic? Sometimes people use read automatic gearbox oil. This destroys all the gaskets in pump and gear actuator. -
16
Antriebswellenflasch ausbauen
Und wenn wir dabei sind: Schlitz-Schraubenzieher in die belüftete Bremsscheibe, entweder unterm oder überm Sattel je nachdem, ob man Lösen oder Anziehen will -
A2 tdi 75 PS AMF OSS 5-Sitzer Zylinderkopfdichtung defekt
Liebes Forum, der blaue A2 soll mich wieder verlassen. Ich werde die doch nicht wenigen Baustellen nicht alle beseitigen können, weshalb er sicherlich bei einem Schrauber in besseren Händen ist ( ich muss dann auch nicht mehr so viele laienhafte Fragen stellen, also schlagt zu :-)). Technische Daten: blauer A2, OSS (geht nicht auf, Motor greift nicht), blaues Leder, 5-Sitzer, AMF, EZ 5/2003, großes FIS, Sitzheizung, Radio Folgende Dinge sind defekt (ich versuche ehrlich zu sein und nichts zu vergessen, kann allerdings nicht garantieren, dass ich Dinge vergesse) - Zylinderkopf/Dichtung bläst Abgase ins Kühlwasser, Kühlwasser geht raus--> nachfüllen, bei mir etwa alle 50km - Klimaanlage und Lüfter gehen nicht, das sind wohl Folgeprobleme der ZK-Problematik - OSS defekt, habe letztes WE den Seilzugrep.satz montiert, alles geschmiert, der Motor muss noch so eingebaut werden, dass er die Seilzüge packt. - Scheinwerfer müssen unterschiedlich fest poliert oder ausgetauscht werden. - Rücksitzbank: die Lehnenverriegelung muss man händisch hochziehen, entriegeln geht aber. - zieht beim Fahren ganz leicht nach links--> Spur einstellen - vorne links ist eine leichte Unwucht ab 80 zu spüren - Steinschlag in der Scheibe, jedoch nicht im Sichtfeld - Hutablage/Heckrollo und Bordbuch fehlen. Neue Lima, neuer Anlasser, neuer Ventildeckel. Neuer Doppelgeber, neuer Klimahochdruckschalter, Zahnriemen erst gewechselt, wer das war, weiss ich nicht, vielleicht wurde da der Motorfehler reingeschraubt... Vieles davon wurde mir beim Kauf (06/2025) verheimlicht, ich möchte es besser machen. Ich weiss, was der Schrotti für die Alukugel gibt, deshalb gebe ich ihn nur für etwas mehr ab. Schlachten kann ich zur Not auch. Bei Kleinanzeigen sieht man mit den Suchworten eine Anzeige mit Bildern. Standort Ravensburg, vermutlich ab 29.09.25 abgemeldet. Fährt und bremst, weitere Abholstrecken empfehle ich nur per Anhänger... Forumspreis: 1.100.-€ Mein Mech wollte lieber einen Ersatzmotor einbauen, den ich auch schon geordert habe, den ich zu meinem Kaufpreis (500.-€ ohne Versand, hat die üblichen 111.000km gelaufen, AMF aus einem Polo ) mit verkaufen kann. Melde Dich gerne per PN, wir können gegen Angabe einer Nummer auch gerne telefonieren. -
36
Could you confirm above question? Not staring or starter not being activated? If hydraulic pressure is too low, the pump would be my first guess. -
16
Eine kurze Nuss ist ausreichend.Eine lange Nuss ist nicht zwingend erforderlich. Man braucht aufgrund den Länge der Antriebswellen min. eine Verlängerung. Ich habe die Tage gerade einen Motor ausgebaut und bin mit einer kurzen und langen Verlängerung klar gekommen. Wer es komfortabler mag, nimmt 2 lange Verlängerungen. -
16
Am besten bestellst Du gleich so ein Set, dann hast Du für alle Eventualitäten was vorrätig -
16
Ideal 150mm, geht aber auch mit dem kurzen... Mann mann mann -
16
ja genau und wie lang muss der Vielzahn M10 mindestens sein. Wäre für andere eventuell auch interessant. Gruß -
542
Anleitung Ausbau Stellmotoren der Klima
Ich habe einfach nur bestellt, ohne das mir bewusst war, das es noch eine Auswahlmöglichkeit gibt. Ich hatte mich einfach auf das Bild (grün mit 150Grad) velassen. Bekommen habe ich weiße. 9 Stück mit 160Grad, dann noch welche mit 120, 250, 320Grad und mehrere, die gar nicht beschriftet sind, deren Werte aber nicht den 160Grad entsprechen.
